Example Code
IMAQdx Continuous Grab & User Triggered Snap
Products and Environment
    Hardware
  • Machine Vision
    Software
  • LabVIEW
    Driver
  • NI Vision Acquistion Software
Code and Documents
Description
Overview
Perform a software trigger to grab a specific image from the camera.
Description
This example uses IMAQdx to continuously acquire (grab) images from an IMAQdx camera. The example also uses a user push button 'trigger' to transfer an image to a buffer, thus creating a snapshot.
Requirements
LabVIEW 8.6 "or compatible"
Vision Acquisition Software 8.6 "or compatible"
-Open and run the exmple.
-Follow the instructions listed on the block diagram
This example requires that you have the IMAQdx driver installed
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Hope this helps.
-Ben
WaterlooLabs
Comments
learningaboutoptics
Member
Member
on
 If I'd like to do processing on the 'snap' inside of the case structure, how do I transfer the snap image data back out of the case structure? Basically, in this example the snap image is transferred into a buffer, but how would I get that same image back out?
Contributors
