Example Code
IMAQ Threshold Binary Image and Mask
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
The example demonstrates how to apply a binary threshold to an image.
Description
For some VISION algorithms, a binary image is necessary to perform the calculation. Threshold your grayscale or color image to create a binary image. Creating a binary image separates the objects that you want to inspect from the background. The threshold operation sets the background pixels to 0 in the binary image, while setting the object pixels to a non-zero value. Object pixels have a value of 1 by default, but you can set the object pixels to have any value you choose.
After creating a binary image of the original image, a masked image is created by applying the binary image as an image mask to the original image. The masked image contains the grayscale representation of the original image, but the parts of the binary image that are considered background pixels are blacked out in the masked image.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Run the VI
  2. Adjust the 'Lower Value' and 'Upper Value' sliders
Create a Binary Image - NI Vision 2011 for LabVIEW Help
http://zone.ni.com/reference/en-XX/help/370281P-01/nivisionlvbasics/create_a_binary_image/
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Isaac S.
