Example Code
IMAQ Active Zoom Example
Code and Documents
Introduction
This example actively enlarges an image by resampling base upon where the mouse is located. This example works for both IMAQdx and IMAQ and can be used with RGB 32 and Grayscale I 16 and I 8  images. The example consits of IMAQ Active Zoom 2009.vi and its sub VI rectangle generator 2009.vi. Rectangle Generator is used to setup the feild of the zoom. This example could be used in any event where you want to get a closer active inspection on an image without having to zoom in and out.
Thank You
Eric Reid
Motion R&D
Contributors
