VI Information
Flir Public Files are a format used by Flir Systems. We can use LabVIEW to extract header information regarding the image file aswell as the pixel data.
The header file is a 892 byte data structure. This contains data from image data, camera data, object parameters, date and time, and scaling data.
Such information includes
The following vi uses a functional subvi, with an enum selector to read this data back from the header information. The U32 enum is made up from the header offset, the length of information to read, and data type. The output is always converted to string.
Main VI
SubVI
Steps to Run
Points to note about the vi
Required software
Related example code
How to read fpf (Flir Public Files) using LabVIEW Vision Development Module : http://decibel.ni.com/content/docs/DOC-13572
