Example Code
How to convert a LabVIEW array to a .NET ArrayList
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview: This example shows how to convert a LabVIEW array to a .NET ArrayList so that it can be used in .NET Property and Invoke Nodes that require an ArrayList.
Description:
This example shows how to convert a LabVIEW array to a .NET ArrayList so that it can be used in .NET Property and Invoke Nodes that require an ArrayList. Could be used as a subVI.
Requirements: LabVIEW 2012 (or compatible). Hardware: none.
Steps to Implement or Execute Code:
1. Insert Array items.
2. Run the VI.
Additional Information or References:
Jared S.
Applications Engineering
