Example Code
How to Stop Parallel Loops Using Occurrences
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI shows how to stop parallel loops using Occurences
Description
Labview is the best one when working with parallel loops for multi tasking purposes. However stoping multiple loops is somehow complicated.
This is because it is not possible to create local variable to a boolean control with latch property.
There are many solutions to this; One is using occurences found on syncronization functions subpalette.
Requirements
LabVIEW 2012 (or Compatible)
Run the Vi
Push Stop Button
VI Block Diagram
 Stop using Occurrence LV_2012_NI_Verified.pngStop using Occurrence LV_2012_NI_Verified.png
Comments
NI-hilator
Member
Member
on
I like this method but if one of the loops contains a long delay then the stop is also delayed, right?  How do you stop a loop with a Wait or Time Delay?  I've seen examples of this using events, but I have the base development systems which doesn't have events.
eng.3zam
Member
Member
on
nice method to solve the problem >>> but can you explain the idea of method ?
