Example Code
How to Select Which Signals to Display and Save Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example chooses which of those channels to save and display depending on user input.
Description
This example we are using an Express VI to simulate a signal.  Based on which Booleans the selects, the program will index through the signals and build a new one.  This new array is what is inputted to the graph indicator and also to the Write to Spreadsheet File
Requirements
  • LabVIEW 2012 (or compatible)
  1. Unzip the attached folder to your computer
  2. Open the VI "Select Waveforms to Display and Save 2012 NIVerified"
  3. Run the program
VI Snippet
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
Comments
Maciej_Antonik
NI Employee (retired)
on
Wouldn't it be easier to use Select Signals Express VI?
Maciej Antonik
National Instruments Poland
Tejinder_G.
on
Actually, you're right!  I guess I didn't search the Express Palette before writing this.  Good catch.
Tejinder Gill
