Overview
This VI relates to how to programmatically search a string in an array of strings.
Description
You can use this VI to search the first element of a string array that contains a specific substring. You can also choose to make that search case insensitive. This VI is composed by a conditional for loop that contains "match regular expression" and the exit condition is if the match regular expression function detect a substring, after that there is a case structure that manage the element not found case or show the element that contains the substring.
Requirements
VI Block Diagram
