Example Code
How to Rotate a .wrl File in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to open and manipulate a 3D WRL model
Description
A .wrl is created from many different 3D modeling languages. The nice thing with LabVIEW, is that you can see these 3D models in a 3D picture control. While the model can be rotated by changing the camera controller and using your mouse, you can also use the built in subVIs to manipulate the model.
Requirements
LabVIEW Full Development System 2012 or compatible
Steps to Implement or Execute Code:
1- Enter the .wrl model file path
2- Run the VI
3- Move the model by clicking and dragging inside the 3D picture
4- Test the automatic rotation using the boolean controls (Rotate X,Y,Z)
VI Block Diagram
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Chris Van Horn
