Overview
Sometimes a user simply wants to see the output of a DAQ devices and is uninterested in logging that data or getting specific values. In this case it's appropriate to simply launch a MAX test panel to quickly look at what a DAQ card can do.
Description:
This VI will allow a user to launch a MAX test panel from the command line. This example is inspired from this Knowledge Base Article: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGrsCAG&l=en-US
Steps to implement or execute code
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 9.0 or compatible
Hardware
cDAQ with C series Module
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
