Functional Description
This Community post is to support KnowledgeBase 4SA8N6CX: How to Create Child LabVIEW Libraries (lvlib) Using Distributed System Manager (DSM) and LabVIEW Dat.... Please refer to this article for more information on modifications being made.
In the project explorer if you create a library to store shared variables this can be done both manually and programmatically, by using the DSC Module. You can also create a variable for this library manually or programmatically, once again using the DSC Module. For some applications it is desirable to have the shared variable structure, in the project explorer or in the Distributed System Manager (DSM) to reflect the real world system architecture.
For example, if you have several power stations, with several generators, which then have parameters your acquiring/monitoring. To create this manually it is more of the same, just right-click on the library (parent library) and create new library.
However, programmatically this is rather more challenging. This is because this architecture is not maintained in the Shared Variable Engine, a process is just a process. However, it is possible to workaround this limitation. This is done by editing the xlm file which has the Operating System will name LabVIEW Library file (lvlib). You can view the xml data by selecting to open the file with Wordpad or Notepad.
Note: It is not recommenced to edit xlm data and this is unsupported.
These files, both the parent and child (sub) libraries require a few alterations in the correct order.
Notes: Notice Parent & Child, with a variable status. To the right is the pop-up that is generated. Once ok is selected the libraries/processes are removed.
Caveats and Additional Notes
Example code attached is in LabVIEW 8.6.
Within zip file contains LabVIEW Project and the required subVIs.
