Overview
This VI shows how to program Elapsed Time Express VI's in Sequential Order
Description
The Elapsed Time Express VI, by default, will begin its next iteration immediately after it concludes its preceding iteration. If you use multiple Elapsed Time Express VI's to count or control a while loop the "default" behavior will not produce the results you want. Using shift registers to control the resetting of the Express VI you can easily get the desired behavior. This example shows how to do this.
Requirements
LabVIEW 2012 or compatible
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
The default of manual reset is FALSE, so don't really need the shift registers in this case
Try it without the shift registers and watch the indicators. I think you'll see the problem.
