Example Code
How to Ping another computer from within LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
To Ping the Desired Website using the LabVIEW
Description:
Here is how to ping another computer from within LabVIEW. This can be very useful when needing to check the connectivity of a computer on the network.
Instructions:
To implement this example:
  1. Run the VI
  2. (Optional) Change the desired website to ping by accessing the block diagram
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Joe Daily
may the G be with you ....
