Example Code
How to Kill a Windows Process from Within LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
To Demonstrate How the VI would Kill a Windows Task
Description:
The VI would demonstrate how to programmatically use the System Command.vi to basically kill a running executable within
the Windows OS, with the example of Solitaire.exe
Instructions:
To implement this example:
  1. Run the VI
  2. (Optional) Change the executable that you would like to kill by accessing the block diagram
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Joe Daily
may the G be with you ....
