Example Code
How to Extract Information from Strings Sent from External Sources.
Code and Documents
Overview
This example VI provides several approaches to extract data from strings sent from external equipment.
Description
Usually, you can use “regular expression pattern matching” to find a certain format from the equipment output string. But, this VI shows you several methods to get important data from the long string if know the certain location of the important data in the string. In the VI, a long string displayed as Hex represents data from the equipment, four methods get 3 bytes starting at position 9 and show the data as U32, array of U8 values or a String.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached folder to your computer
  2. Open the VI " Byte Manipulations 2012 NIVerified.vi"
  3. Run the program
VI Snippet
Stephen C
Comments
KRAZE4LV
Active Participant
Active Participant
on
please send your porgram in LV 2009 or 2010
