Introduction
There has been a number of questions about how to incorporate the Vision Assistant into a LabVIEW VI. This example will hopefully illustrate how easy it is to use. All this example does is acquire images and performs a threshold on the image. The acquired image and the processed image are both displayed on the front panel.
Steps to Complete
This example uses the IMAQdx driver; thus use a Firewire or a GigE camera with this. Just select the camera you want to use and press the run arrow.
you can give me document :
hi my question is how to define or create good and bad image in my sample image using threshold level.good image
shaded image
