Example Code
How To Combine Two WAV Files In LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to merge the sound from two WAV files together and display the resulting new signal in LabVIEW.
Description
The example VI is built on the community example How to Play a WAV File in LabVIEW. Two WAV files are first opened and then the information of them is extracted by the Sound File Read functions. We then combine the information from the both WAV files and write the resulting sound to the Sound Output Write function to play it.
Requirements
  • LabVIEW 2012 (or compatible), A speaker
  1. Download the attached file (Play Two Sounds 2012 NIVerified.zip)
  2. Enter the correct paths of the two WAV. files you just downloaded in the VI front panel
  3. Run Play Two Sounds 2012 NIVerified.vi to hear the chord.
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
