Overview
When taking in measurements from a device it's sometimes worth keeping note of the highest value or peak that was input.
Description
By using shift registers you can keep hold of the values that have been input. By processing these values with the "Min & Max" function you can keep hold of the largest value. This program uses a numeric control as an input source, this could quite easily be changed to a DAQmx Analogue Input channel instead. It also has a Reset button that will directly wire a value of "0" into the shift register. This will wipe the data that it is currently holding onto.
Steps to implement or execute code
- Download the attached "Peak Value.vi"
- Open the vi and click run
- Notice that as the value on the dial increases so does the value on the "Peak Value" indictor
- Now lower the value of the dial and see that the "Peak Value" indicator keeps it's value
Requirements to Run
Software
LabVIEW 8.6 or newer
Additional Images
