Example Code
Highlight Array Element
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example highlights an element in an array with the color you choose.
Description
This example highlights an element in an array with the color you choose. It works because the background of the array is transparent and an array of color boxes is located behind the transparent array. Changing the color box array determines which cell of the top array is highlighted.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI
  2. Specify which cell in the top array is highlighted and the highlight color.
Front Panel
Block Diagram
Making this look nice on the front panel just takes some precise resizing and transparency tweaking. Good luck!
Product Support Engineer
