Example Code
Hide .NET Picture Box at front panel programmatically
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
I want to move the the .NET picture box to the back of the waveform chart. I tried to use "Move Backward" & "Move to back" command under "Reorder" menu bar on the front panel but the .NET picture box always locate in front of waveform chart.
Expected Result:
Error Result:
How to Use
There's no way to reorder the .NET picture box in front panel. In simple term, .NET picture box is opened as "new window" , therefore it always be located at the front of the front panel object.
Alternative way is hide the .NET picture box programmatically in LabVIEW by using property node.
  1. Right click Picture box in block diagram. Select Create >> Property Node >> Visible
  2. Right click the property node and select Change All To Write
  3. Create a false constant and link to it
Additional Information
Create a while loop and link false constant at loop terminal. When the VI is running, the .NET picture will be hide until the VI is stopped.
