Example Code
Hide Main Front Panel Window in SubVI
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code allows the user to Hide the Main VI from SubVI adjusting the transparency for the Main Front Panel.
Description
The Main VI uses a subVI where a slide button allows the user to adjust the transparency of the Main VI Front Panel uses a Property Node (Run VI Transparently).
Requirements
LabVIEW 2012 (or compatible)
  1. Run VI
  2. Click on Run SubVI Button
  3. Adjust Transparency of the Front Panel Main from the Front Panel SubVI
Andy Chang
Comments
leamon
Member
Member
on
when i run main-fp, lost the "chris_sub.vi",when i run the sub fp,the program exit automatically
Andy_C.
NI Employee (retired)
on
Thanks for the feedback! I've fixed the Main VI.
Andy Chang
