Example Code
Hardware Timed CAN Bus Loader
Code and Documents
Functional Description
This program will create multiple CAN objects simply transmit CAN frames with multiple objects.  This will put a partial load on the bus.
Caveats and Additional Notes
This example will not allow you to fully load the bus.  To do that you will need multiple CAN cards or use the network interface instead of CAN objects.
Caleb W
Comments
leo2b
Member
Member
on
Bonjour,
Serait-il possible de l'avoir pour la version 8.5 svp?
Merci
Caleb_W
NI Employee (retired)
on
Just attached an 8.5 version.  Enjoy!
Caleb W
uhzzhu
Member
Member
on
还要加载ncclose.vi是怎么回事啊?这些是要自己编写的吗还是例程里面就有?
Contributors
