Example Code
Handling the Timeout Error to Fetch All Data from Onboard Memory with NI HSDIO Devices
Products and Environment
    Hardware
  • Modular Instrumentation
    Software
  • LabVIEW
    Driver
  • Other
Code and Documents
Description
Overview
    This example shows how to generate synchronized digital data with multiple HSDIO devices using only one HWS File.
Description
    This example demonstrates how to setup an acquisition designed to capture 1000 samples.  In the event that the device times out and doesn't receive a reference trigger, the code will handle that error and acquire 100,000 samples relative to the first sample.  This is a way to dump the memory in the case that you don't receive a trigger.
Requirements
    Software
        LabVIEW 2012 (or compatible)
        NI-HSDIO driver which is compatible with your hardware and version of LabVIEW
    Hardware
        PXI-655x
Instructions
    1. Select HWS file.
    2. Run the VI.
