Overview
This example handles the "Error 5 - File already open” generated when opening an already opened file
Description
Sometimes you may have are multiple programs accessing the same data file. If LabVIEW tries opening a file that is another program already has control of (such as data backup software), you will get error 5 when trying to open the file in LabVIEW. This can cause problems if you are logging data and need all of it to be written to the file. This problem can be avoided if you use queues to write the data, and handle this specific error.
Requirements
LabVIEW Full Development System 2012 or compatible
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
"Close file reference" should be inside "No error" case structure, else error code 5 generates error code 1 after passing thru "Close file reference" (because input file reference is invalid).
