Overview
This example shows you how to graphically draw an arbitrary waveform.
Description
If for any reason you need to graphically draw an arbitrary waveform that can write to AO and is modifiable during run-time there is this solution. Note that the example is not perfect but allows a user to draw a waveform which can be output to hardware, for instance with DAQmx.
Requirements
Define the number of samples the waveform will contain and the dt of the waveform before drawing the waveform.
VI Snippet
There is also this example here.
