Overview
This example programmatically changes the plot names and colours on a Waveform Graph which contains multiple plots.
Description
This is a simple example that programmatically changes the plot names and colours on a Waveform Graph which contains multiple plots. This could be used in an application where data channels are selected but may not always be used.
The basic operation of this VI is to read an array of strings into a For loop with auto-indexing enabled. The For loop will execute for however many entries there are in the array. The selected plot is set by the iteration of the loop. The colour of the plot also changes based on the Plot name.
Requirements
LabVIEW Base Development System 2012 or compatible
VI Block Diagram
The Color Box allows you to change the colour of the plot.
**This document has been updated to meet the current required format for the NI Code Exchange. **
Do you know if it is possible to change the plot names on a waveforem chart (not a graph)?
