Example Code
Graph Extract Tool
Code and Documents
Overview
This tool allows the user to select a part of a waveform from a .tdms file and then save and extract as a new waveform in a .tdms file.
Description
The program uses the low level file I/O functions to open and save the .tdms files. The manipulation of the graph on the front panel is read using a property node that give the minimum and maximum values to the X scale. With the graphs dt value, the specific sample number in the array of the start point and length in samples can be calculated. The array subset function can then be used to extract the desired section with these parameters. The extracted section is then saved using the low level .tdms file I/O VIs.
  1. Run the VI
  2. A prompt will appear asking the user to select a file to load
  3. Zoom in on the section of the data that you is to be extracted
  4. Click the "Graph Extract Found" button
  5. A user prompt will appear asking for the location and file name for the new extract to be saved
  6. The program stops running and the new file is created
Requirements
Software
LabVIEW 2010 or later
Additional Images or Video
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Matt Surridge
Contributors
