Example Code
Get String from Listbox in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Demonstrates how to access Listbox strings using Property Node.
Description
The example uses Property Node to get Item Names property in a 1D array of string of the Listbox. The selected string in the Listbox returns the position of the string in the array. Index Array is used to return the element in the array.
Requirements
LabVIEW 2012 (or compatible)
  1. Run the program
  2. Click on any string inside the Listbox
  3. The string selected and its position will be displayed
  4. Click "Stop Button" to stop the program
Additional Information or Resources
VI Block Diagram
George T.
Senior Applications Engineer
National Instruments UK and Ireland
