Example Code
Get Record Set from Database and Include Column Headers Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI gets a Record set from database and include the column headers.
Description
This VI will return a Record set with the option to include the column names in the first row of a multidimensional string array created on the fly from the tables you wish to read.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Change the Connection String, Table String and Selection String to your requirements.
  2. Run the VI.
VI Snippet
A picture paints a thousand words, A video has thousands of pictures.
All help files should be viewed as video.
Comments
hsalman
Member
Member
on
Is there a way to select the column headers after the query has been executed? For example, I am selecting data from different tables using JOIN, so my result would be different columns from separate tables. I want to be able to see the column headers.
Softman
Member
Member
on
Hi hsalman
'Get Column List' should contain what you need.
