Example Code
Genius - Game using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates the famous game-Genius.
Description
Here is a brief description of the example:
This example code shows how to program the famous game. There are two stages. The first stage is that the computer will light the different color LEDS by the certain order, and then the player can press the related LEDS according to the computer’s order in the second stage. Finally, you can get the high score.
Note: the times of lighting LEDs is increased step by step.
Requirements
  1. LabVIEW 2013 (or compatible)
  1. Start the game
  2. Firstly, the computer will light the LEDS according to the certain order
  3. Then, it's player's turn to press the button according to the shining order by computer.
  4. If the wrong button is pressed, the game is over
  5. You can get score when pressing correct button
VI Snippet
Comments
NJKirchner
Active Participant
Active Participant
on
Very clever.
I would like to see how you would re-code it without the excessive usage of local variables.
