Description
Description-Separate-1This article demonstrates how to read and write data to and from a module on a simulated FPGA Target from LabVIEW. This enables the creation of a test environment that retrieves data from an FPGA VI and displays it on a Host VI. For demonstration purposes, this article utilises a cRIO.
Prerequisites
Before proceeding, ensure that the development PC has the following software installed:
- A version of LabVIEW that is compatible with the PC's operating system.
- A version of the LabVIEW FPGA Module that is compatible with LabVIEW.
- A version of the LabVIEW Real-Time Module that is compatible with LabVIEW.
- A version of the device driver that supports the required hardware and LabVIEW version.
Description-Separate-2How to Use
How-Separate-1The attached code offers an example solution for generating simulated FPGA data. Download this and run the example as it is. Alternatively, follow the steps below to create the code from scratch.
Note: These steps reference a cRIO, but the same method can be applied to any real-time target.
- Refer to Simulate FPGA Targets Using the Project Explorer with LabVIEW to set up a simulated cRIO and FPGA in a LabVIEW project.
- For demonstration purposes, this example utilises a cRIO-9030 with a NI-9205 module.
- Right click on the FPGA Target and select New >> VI.
- Save this VI as "FPGA VI".
- In the FPGA VI, place a While Loop with some basic timing.
- All that's required in this VI is a continuously running loop.
- Right-click on the My Computer item in the project tree and select New >> VI.
- Save this VI as "Host VI".
- In the Host VI, place a While Loop with some basic timing. Connect a Boolean Control to the stop condition.
- For demonstration purposes, the While Loop shown uses the Wait (ms) function to force each iteration to take 10 milli-seconds.
- From the Functions Palette, navigate to FPGA Interface and place a FPGA Desktop Execution Node inside the While Loop.
- In the Configure FPGA Desktop Execution Node pop-up, select the Browse Project button and select the FPGA VI from within the project.
- In the Available Resources section, expand the FPGA Target until the required module input/output can be seen.
- Select the desired input(s) or output(s) and click the blue arrow pointing towards the right.
- Click on the input or output under Selected Resources and change the terminal direction as required.
- To write simulated data to the terminal, select In for Change Terminal Direction.
- To only read data from the terminal, select Out for Change Terminal Direction. Note: simulated modules will produce noise or unexpected data if nothing is written to them.
- To both read and write data, select In/Out for Change Terminal Direction.
- Click OK to close the configuration window.
- Use any preferred method to create simulated data points and wire this to the module input of the FPGA Desktop Execution Node.
- For demonstration purposes, this example generates a sinusoidal waveform by using the Sine Wave VI from the Signal Generation Palette. The While Loop incrementally indexes each element in the sine wave array and writes the current element to the FPGA module.
- To read the module data back out and display it on a Waveform Chart:
- Place a Build Array function on the module output of the FPGA Desktop Execution Node.
- On the Front Panel, navigate to Graphs >> Waveform Chart in the Controls Palette. Place down a Waveform Chart.
- Connect the Waveform Chart Indicator to the Build Array output.
How-Separate-2Additional Information
Additional-Separate-1This example code was developed in LabVIEW 2020 SP1 and can only be opened in LabVIEW versions equal to or later than 2020 SP1.
Additional-Separate-2
