Example Code
Generate multiple offset PWM outputs for FPGA
Products and Environment
    Software
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
  • LabVIEW
Code and Documents
Description
Overview
The example demonstrates how to program two PWM signals with a adjustable delay between both signals.
Description
Generating multiple pulse trains using LabVIEW FPGA is relatively simple to code. In this example ('PWM with Offset.vi') two PWM signals are generated with an adjustable delay between both signals (phase shift). There are two implementations doing the same task but the 'Single Cycle Timed Loop (SCTL)' implementation is a little bit more efficient than the 'While Loop' implementation, but more low-level and a little bit harder to read.
Also there is a second example ('PWM with Offset (no FPGA).vi') that only uses standard Windows LabVIEW functions that do not need the LabVIEW FPGA Module. Please be advised that this example is only for demonstration purposes and will very likely not run on a Windows system with full determinism.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • LabVIEW 2012 FPGA Module (or compatible)
  • (Optional) LabVIEW 2012 Real-Time Module (or compatible)
 Hardware
  • 'PWM with Offset (no FPGA).vi': No hardware is necessary to use this example VI
  • 'PWM with Offset.vi': The example VI needs a FPGA with at least two digital outputs.
    (Even though the example is meant to run on hardware the code can also be simulated, when no hardware is available.)
  1. Open the attached file
  2. Select the implementation you want to use
  3. Configure the settings for the respective representation
  4. Run the VI (depending on the execution mode selected it may be necessary to compile the FPGA VI to a FPGA bitfile before)
FPGA implementation
Implementation without FPGA
PWM with Offset (no FPGA) - Front Panel.pngPWM with Offset (no FPGA) - Front Panel.png
PWM with Offset (no FPGA) - Block Diagram.pngPWM with Offset (no FPGA) - Block Diagram.png
KnowledgeBase: Simulate FPGA Hardware Targets Using the Project Explorer with LabVIEW
Tutorial: Testing and Debugging LabVIEW FPGA Code
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Austin S.
Academic Field Engineer
Comments
Austin_S
NI Employee (retired)
on
When converting this code to FPGA, the original code gave errors as the DBL type was not supported for FPGA.  I've updated the code and converted all DBL to Fixed Point data type.  (9/14/2011)
Austin S.
