Overview
This example VI generates sine wave burst, to be outputted continuously.
Description
This VI creates signal, containing a sine wave burst, which you can output continuously. The user can specify the frequency of the sine wave and the duration of the burst, and based on the total number of samples allocated to the signal, and the duty cycle for the burst, the VI determines the appropriate sampling rate which you should output at in order to achieve the desired sine wave burst. An error is thrown if the number of allocated samples is not enough to characterize the sine wave at the desired frequency.
Requirements
VI Block Diagram
