Example Code
Generate Randomized Array of Strings (Configurable Probability) using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
When provided with an array of strings and a corresponding array of numerics (which designates the probability that the string at the same index of the paired array will be "selected"), this VI returns a randomized array of the elements given.
Description
This VI returns a randomized array of the elements given.  It does this by normalizing the probability values provided and comparing them to a random value between 0 and 1.
Requirements
  • LabVIEW 2012( (or compatible)
  1. Run the VI
Front Panel
Block Diagram
Tom L.
