Steps to Implement or Execute Code:
Connection Overview:
The counter will output the pulse train on the output terminal of the counter specified in the Physical Channel I/O control.
For more information on the default counter input and output terminals for your device, open the NI-DAQmx Help, and refer to Counter Signal Connections found under the Device Considerations book in the table of contents.
Block Diagram Steps:
HI,
I am developing a similar code in LabVIEW and need a little assistance. I am using the module NI 9819 chasis along side 9402 4-channel TTL digital I/o, generating a double pulse(mostly) but sometimes with user defined pulse-width and user defined no of pulses.
I am trying to acheive this task but the problem is if I need more than 2 pulses then I need more counter in that case (where I will be using only 2 counters for 2 pulses). Can you suggest me how to acheieve this task.
Thanking you,
