Description
Description-Separate-1Overview
This example toggels the digital output using the selected clock rate based on the 40 Mhz default FPGA timebase.
Introduction
The RIO driver installs scaling VIs for LabVIEW Real-Time and LabVIEW to use with FPGA VIs in order to scale and prepare data for the various FPGA functions. One of those functions is the "Sample Rate to Loop Time" VI which can be used to format a sample rate into ticks, microseconds or milliseconds for use with the loop timer VI. This example demonstrates its use with a PCIe-7852R R-Series card to create a digital clock on DIO0 at the requested frequency.
Requirements:
LabVIEW FPGA 2009 "or compatible"
LabVIEW 2009 "or compatible"
NI RIO 3.3 "or compatible"
NI R-Series device or simulate FPGA target using LabVIEW FPGA
1.) You will need to port this example to your hardware, but it should work correctly with any FPGA device sold by National Instruments
2.) Compile the FPGA code for your hardware (run "FPGA.vi")
3.) Select the prefered clock rate (toggel rate) for the digital output line using the "Host.vi"
4.) Run the host vi
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Description-Separate-2
