Overview
This example demonstrates how to generate an QR and pin code used in Offline 2FA authentication based on a secret key.
Description
2FA authentication is used as an extra layer of protection for user login, it uses TOTP(Time based password) or HOTP(counter based password) for pincode generation.
This program generates a QRcode that is used to register a standard 2FA app(e.g. Google authenticator).
The generated pin code matches the code in the App, Therefore this can be used to authenticate a user.
In the attachment are 2 projects, one using .NET for generating the QR and pin code, the other uses only native Labview code(using library's mentioned in the requirements section).
Requirements
LabVIEW 2016 (or compatible)
For the native Labview project the following library's are needed:
- Crypto tools : https://forums.ni.com/t5/Example-Programs/Cryptography/ta-p/3494085?profile.language=en
- QR generator: https://forums.ni.com/t5/Example-Programs/Offline-QR-Code-Generator-v1-1/ta-p/3496535?profile.langua...
Steps to implement or execute the code are described in the Main VI
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
