Example Code
General CRC calculator (1..32 Bit)
Code and Documents
This are 4 *.vi's, which should help you to calculate CRC. The main VI is CRC_Universal.vi. If you set "Final_XOR_value" to zero it's a CRC-16 CCITT example. The default values are the CRC-16 of GENIbus. GENIbus is a communication protocol of the Grundfos company. You find the specification at https://forums.ni.com/t5/LabVIEW/Has-anyone-any-experiance-of-communication-with-grundfos-pump/m-p/2....
The code is based on the examples of http://zorc.breitbandkatze.de/crc.html. This homepage based on PAINLESS GUIDE TO CRC ERROR DETECTION ALGORITHMS article written by Ross N. Williams.
Contributors
