Example Code
Frequency Domain Cluster (Power Spectrum, FFT) to 2D Array in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI will take any cluster of frequency domain data, such as a Power Spectrum or FFT, and converts it into a 2 dimensional array which can be saved to Excel or a text file.
Description
The frequency domain cluster contains three components: f0 (initial frequency), df (frequency step along X-axis), and magnitude (1D array of magnitude values).
This VI uses f0 and df to create a 1D array of frequency values, and then combines that with the 1D magnitude array.
The result is a 2D array, where the first dimension is frequency data and the second dimension will contain the magnitude at the respective frequency.
Requirements: LabVIEW Base Development System 2012 or compatible
  1. Enter the Frequency Domain Cluster array or Use this VI as subVI
  2. Run the VI
VI Block Diagram
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Eric S.
AE Specialist | Global Support
