1. Overview
This example illustrates how to use timing sources that can be used for frames within a timed loop. You can configure frames to use the same timing source as the timed loop or to have an independent timing source that resets each loop iteration.
2. Description
In this example, two timed loops with four frames each are configured to have two different frame timing configurations. Select the number of loop iterations to simulate along with the duration that each loop frame will take to execute, and the timing results will be plotted on the front panel graphs.
3. Requirements
4. Steps to Implement or Execute Code
5. Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
