Functional Description
This bus loader uses the WriteNetMult.vi to load a CAN bus. You can specify the number of frames and the minimum wait time between each write.
Caveats and Additional Notes
You can tweak the timing to get the appropriate bus load. You will get an overflow error if the Write Entries Pending gets too large. If this is occuring, increase the wait time between each write and decrease the number of frames to write.
