Example Code
Four Channel Gain Function
Products and Environment
    Software
  • LabVIEW Real-Time Module
  • LabVIEW
Code and Documents
Overview
 Integer math scaling of a four channel array in LabVIEW FPGA.
 Description
This example uses integer math to scale an array of four input channels in a LabVIEW FPGA application.  This example will not work within a Single-Cycle Timed Loop, as it uses a Single-Cycle timed loop to index through different channels.Using integer math scaling, the gain value (in percentage) is multiplied by (220)/100 = 10486.  The scaled gain value is then multiplied by the corresponding channel value, and the result is then multiplied by 2(-20).This method of multipling and then dividing by a large power of 2 is a common way of working with integer math in LabVIEW FPGA.
Requirements: LabVIEW 2012 (or compatible), Real-Time Module. Hardware: none.
Steps to Implement or Execute Code:
1. Put Input.
2. Set Gain.
3. Get Output.
4. Write down the results or use as subVI.
Additional Information or References:
