This example contains an NI FlexLogger project, configuration file for simulated hardware, examples to control NI FlexLogger via Python, and getting started documentation.
The Voltage Project (Voltage Project.flxproject) is a FlexLogger project that provides a reference for taking voltage measurements through NI FlexLogger and contains the following predefined FlexLogger documents and files:
FlexLogger Channel Specification
FlexLogger Screen
Note: The Voltage Project has been configured to acquire data from voltage devices with a range of -10 / 10 volts. The hardware configuration may need to be modified to match your sensor's configuration.
Description-Separate-2
Project Execution Buttons
Note: For additional information on the components, configuration, and how to customize the template, open the Getting Started file located inside the Voltage Template.zip file.
How-Separate-2
Related-Separate-2
