Example Code
FlexLogger Strain Template
Products and Environment
    Hardware
  • cDAQ-9171
  • cDAQ-9174
  • cDAQ-9178
  • NI-9237
    Software
  • FlexLogger
Code and Documents
Description
This example contains an NI FlexLogger project, configuration file for simulated hardware, examples to control NI FlexLogger via Python, and getting started documentation.
The Strain Project (Strain Project.flxproject) is a FlexLogger project that provides a reference for taking strain measurements through NI FlexLogger and contains the following predefined FlexLogger documents and files:
  • Channel Specification (.flxio)
  • Logging Specification (.flxcfg)
  • Screen (.flxscr)
  • Test Specification (.flxtest) — A default FlexLogger file that is unchanged for this project.
FlexLogger Channel Specification
FlexLogger Screen
Note: The Strain Project has been configured to acquire data from specific strain gauges. If different gauges are present, the configuration will need to be modified to reflect the correct sensor configuration.
How to Use
  1. Download the example and corresponding files.
  2. Unzip the folder.
  3. To simulate hardware, double click the Simulated Device Configuration.nce file. If you already have hardware connected, go to step 5.
  4. Navigate through the Configuration Import Wizard in NI MAX until the simulated device is imported correctly.
  5. Double click on the Strain Project.flxproject file.
  6. Run the Project by clicking the Run button on the middle top portion of the window.
Project Execution Buttons
Note: For additional information on the components, configuration, and how to customize the template, open the Getting Started file located inside the Strain Template.zip file.
Related Links
Contributors
