Overview
Filter array elements between a specified minimum and maximum value.
Description
This example will search through an array of randomly generated values and pull out the values that are within a user-defined range. A new array is created with the values that are within the specified range and displays them on the front panel.
Requirements
VI Snippet
You can get rid of the boolean logic by using the "in range and coerce" function. Also I dont think initalizing the array, is efficient in this case.
