以下に示された製品を含め、NIのソフトウェアをダウンロードするには、ni.com/downloadsをご覧ください。
1. Overview:
This example shows how to code a program that calculates how long a button is pressed using an event structure.
2. Description:
This VI uses the properties of the event structure to calculate the time a button is pressed. As the structure provides the time for the Mouse Down and Mouse Up events, the time between them can be calculated by taking a timestamp in the Mouse Down event and subtracting it to the timestamp provided in the Mouse Up event. This is how the code is implemented in this example.
3. Requirements
4. Steps to Implement or Execute Code
5. Additional Information or References
VI Block Diagram
NIコミュニティのサンプルコード交換のサンプルコードは、MIT Licenseによりライセンス供与されています。
