Example Code
Find default program according to extension using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to use the System Exec.vi to use a cmd line prompt command to find the default program associated with a certain file extension
Description
The System Exec.vi is a way to send cmd line strings directly to the command line prompt. This VI shows how to use this function to know what program is associated with a specific file type
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the VI and open it.
  2. Type in the file extension (.vi, .dox, .ppt)Click on the Find Default Program button
  3. Click on the Set Default Programs button to open the Windows options to change the default program if desired
VI Block Diagram
Daniel G.
Semiconductor & Wireless
