Example Code
Find The Most Recent File in a Folder of Files Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI takes in a listing of files from a folder path, finds out all the files in the folder, and returns the path to the most recent file.
Description
Finding the most recent file in the specified folder can be challenging and needed for some applications. Thanks to this example, a user can get the most recent file programmatically.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Select folder for searching most recent file.
2. Run VI.
3. Observe most recent file at File Path Out indicator
Jeff | LabVIEW Software Engineer
Comments
rivand
Member
Member
on
Check the List Folder VI.
Jayberns1919
Member
Member
on
This vi returns a folder not a file..?
James_W
Active Participant
Active Participant
on
The issue with this is it returns files in modification date, and if someone opens a file after it is created it will affect the last modified date used by this function - better to put an ISO 8601 timestamp in the filename! - safer long term from manual intervention.
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
