Example Code
Filtered Data Portal Search with DIAdem Dialog
Code and Documents
Overview
This dialog performs a filtered group and channel search within the data portal.
Description
  • First, the dialog search window is populated with the search entries in the data portal (if applicable).
  • Write_Box_X() transfers the filter strings to the data portal.
  • Refresh_Box_X() inserts the results into the list box.
  • For the group and channel filter search, events are present, so the search is happening automatically (the Data Portal has the same feature).
  • The Button "Select" triggers an output which returns the name and index of the marked item.
Hardware and Software Requirements
DIAdem Base 2011 (or compatible)
1. Download Filtered Data Portal Search - DIA2011.SUD
2. In the Script Editor (ensure that your script is in the same directory), you can call the dialog using
Call SUDDefLoad(CurrentScriptPath & "Filtered Data Portal Search - DIA2011.SUD")
Call SUDDlgShow("Dialog_Box")
Eric H.
Applications Engineering
Contributors
