Example Code
Filter through Multiple IP Addresses Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows a quick way to filter the specific IP address on your computer if your computer have multiple IP address.
Description
If you are trying to locate a specific IP address on your computer, but you have multiple IP addresses (or many subnets), this VI will filter through them all. If you know a unique part of your IP address, you can search through all addresses on computer and choose the IP you need.
Requirements
  • LabVIEW 2012 (or compatible)
  • Select the IP address and IP to match.
  • Run the program
VI Snippet
